Posts: 39 |
Hey everyone, When lift goes downward direction left brake apply late whereas lift goes upward direction right brake apply late. May anyone guide me ??
Posts: 736 |
Sorry I am in USA. One brake is used for Emergency Brake and does not normally drop until goes to sleep. Other Brake picks and drops with runs. Make sure you do not have a magnetic residual issue (Metal touching that shouldn't).
Posts: 39 |
Hey Rolly, thank you, your advised but there is no any magnetic residual. will you advice any thing else?
Posts: 736 |
Check the Parameters. What version of software you have and which CPU, 561 or 40?
Posts: 39 |
Hey roll, Software version is 3.19 CPU 40. Kindly advise me
Posts: 736 |
OMG 3.19 is soooo old you could have many problems if that is in the cpu. Need at least 6.7.25 What country are you in?
Posts: 39 |
Hahaha, yes this is very old version in Pakistan but kindly advise me solution
Posts: 736 |
Upgrade all lifts software..
Posts: 39 |
Posts: 11 |
Rolly I think he’s talking about the KDL16s software 3.19 which is fairly new. On the other hand, CPU SOFTWARE under 6.7.25 won’t work with KDL16s anyways. He’s probably referring to menu 6-97 which refers to drive software. At least I hope he is lol
Posts: 11 |
Posts: 736 |
Could be, don't even know what country he is in.
Posts: 39 |
Dear everyone, i hope, you all are happy. lift is not floor level on EBD but when lift is on floor level then door will open. fault occurs 0105, 0213. kindly advice me what can be happen.
Posts: 93 |
0105 is power supply problem and or braking resistor broken and fault 0213 is no floor nodes found (probably linked to power supply problems).
Posts: 4 |
Dear all who have a idea for kone MX 18 model . We can’t start generator power because error 213 showed.
Posts: 14 |
Newly joined how can I ask questions embarrassing to admit this new tech is a challenge
Posts: 14 |
Posts: 14 |
Just joined how can i post a question is there a icon or title so I can ask questions
Posts: 39 |
hi davidneel, check shaft network power supply or XM13 connector.
Posts: 4 |
