TommyBoy
TommyBoy
I need help with this one. I have recabled the system and get power but the car won't move when called. There is power to all relay switches, so does anyone have any suggestions of what i should try? I can manually push in the magnet contacts and the car moves just fine, but it won't move when any call button is pushed. I have tried replacing relays but no fix yet...any help would be appreciated.
Do you have a print? I have a 1FSOB C-6810. PM me an email will scan and send. Does it run from car buttons and not hall? Does anything on controller pick up at all? If not you need the print.
Also have a 1-SOB A-7383
How much power have you at the Relais? Please take a Voltmeter
Did you try calling unitec with the machine number? They can usually get them from you.
When you recabled did you possibly trip a switch in the safety circuit? Check crosshead SOS switch, Governor Switch, Pit switch, and Limit switches, Some of them had a switch on Pit Door if it was a walk in pit. Not much else there except doors, gates, &fuses.
PHP: 8.3.33 Page Time: 0.022s Queries: 26 (0.005s) Memory: 3.0183 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 01:39:14 UTC
