0 members (), 42 guests, and 2 robots.
#22574 12/23/17 11:55 PM
Hi all!
I have adjusted many valves before, but I need extra help for this one. The valve seems to be adjusted properly, but if the car sits idle for more than a few minutes the next up opening is very harsh. By UP opening I mean even before the UA (UP Acceleration) because I can definitely feel the UA to full speed and it is nicely adjusted. It almost feels as if the valve is internally losing its "prime". Any ideas?
Thanks,
Tight packing will cause a rough breakaway. This can’t be compensated for with valve adjustments.
I usually apply CAT oil directly to the piston to buy me a few days of smoother operation until the packing can be replaced. The Cat oil will smooth out the take off within a couple runs but ultimately the packing has to be replaced with a fresh set. Kind of sucks when you have to replace a packing that does not leak a drop.
Definitely packing related. Check for sticky varnish or rings from the oil getting overheated. Try cleaning this off with a strong hand cleaner, Scrubs in a Bucket work good. You can also scuff the piston with Emory cloth or even install a sanding ring but I wouldn’t go that far unless a re-pack doesn’t solve it.
"Breakaway" that's the word I was looking for! Thanks for the input guys. As Ranger said it is a shame to replace a packing when it doesn't leak at all, but if that's what the problem is so be it. I'll order a new one. Thanks for the tips guys.
Try putting some STP on packing and piston if it's sticking. Used to work great on Otis selectors stop lugs.
PHP: 8.3.33 Page Time: 0.027s Queries: 26 (0.005s) Memory: 3.0191 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 08:32:54 UTC
