#22683 01/09/18 03:00 PM
I’m working on an old Otis B Base 5 stop duplex.
On one car, it closes the doors when the c.o.p. Inspect switch is turned on for hoistway access. You can open the doors by holding the door open button, but the doors close as soon as you let off the button and the light curtain does not reopen the doors. This car has a newer Otis belt drive door operator. I’m having a difficult time determining where the “door close” signal is coming from.
Also both cars close the doors when Independent service is on or when the in car stop switch is on stop. Independent service will work, but to get the cars to run on independent the door close button has to be pressed after the doors are physically closed. Calls will latch with the stop switch in the stop position, but it doesn’t run until the switch is turned back to run. The door open button and breaking the light curtain both reopen the doors.
I have hit a wall and would appreciate and help or direction
Thanks!
Joe
Make sure the door close button back contacts are not open. They are normally closed and the car panels can change size with the weather humidity enough to open the contacts if they are close..
Thanks for the input, I will check it out the next time I’m there and report back
Len Offline
...I had 17 B Base cars down the shore..alot of the problems are the boards in the operational..all door operations are driven from these cards all inputs go to ground to fire the xdo and dropping it as well for the door close ,you have to look at the operational prints they show board locations as well as their respective functions..
Len Offline
Len Offline
''''''Sounds like you might be loosing the SMG on independent if Smg is red.on Indendent b base inputs signal to ground xdo and open the doors
PHP: 8.3.33 Page Time: 0.027s Queries: 26 (0.005s) Memory: 3.0197 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 21:17:23 UTC
