#22938 02/04/18 03:09 AM
Does anyone have a list of faults for an Otis 211. I have to go to an out of town job on Monday and according to customer, display after reset shows MUSS I think this has to do with the starter or the motor up to speed contact on the motor starter. Any help would be appreciated.
Johnny #22939 02/04/18 03:42 AM
PM me your email will send you something.
Johnny #22941 02/04/18 05:24 AM
MUSS = motor up to speed contact failed to open in solid state starter
Johnny #22944 02/04/18 04:17 PM
Bring a logic board. Or if up to speed is stuck closed you can brake off the little surface mount cap that shorts around the SSR contact. It’s almost always the problem, so much so that they don’t put it on the new boards.
Johnny #22954 02/05/18 07:23 PM
The MUSS fault is is a well documented symptom resulting from a failure in the soft starter. The Otis solution is to provide the signal through an added timer and the Run Input.
Johnny #22958 02/05/18 10:03 PM
Yes I have seen the Otis bulletin on adding a timer to simulate up to speed. But for a Siemens starter it seems non-sensical.
Johnny #22961 02/06/18 05:19 AM
Yup. You're right about that.
Johnny #23000 02/09/18 07:00 AM
Put the timer on per otis direction. Well somewhat, anyway. Also replaced the logic card in the Siemens starter for good measure. All is well and elevator is happy once again. Close to 1,000,000 trips on the unit. Thanks to all, especially Rolly and Jon.
Indirtwetrust #40535 12/31/25 06:35 PM
Does anybody have a picture of this capacitor where it is on the logic board?
PHP: 8.3.33 Page Time: 0.031s Queries: 32 (0.006s) Memory: 3.0348 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 01:38:35 UTC
