We're looking for someone to work on this older residential elevator. It behaves as if the gate switch seems to be the culprit. We have all the wiring diagrams as well as the build spec sheet, installation manual, and operators manual (we scanned everything to pdf if you want to see it). We are located in zip 35613.
We contacted the company we bought originally bought it from in 1999, but they no longer service this model. My mother is dying and will rely on this elevator for her mobility as she is getting too weak for stairs.
History of service is follows:
1999 installation complete and operation normal
~2010 elevator would intermittently stop between floors/not respond to hallway or car call buttons. It seems that opening and closing the gate manually (actuating the gate switch) would sometimes fix the issue. Elevator was no longer used because of this.
2010-2017 elevator was not regularly used, but was otherwise usable if the gate switch allowed operation
2017 my dying mother desperately needing the elevator tried a hall call switch and the elevator worked. I tested the operation several times and it seemed like the issue was gone. After a few months of perfect operation, the elevator stopped one night with her still in the car--not good. I was able to open the door (using the Dover provided tools) and get her out safely. Elevator use was again discontinued.
2018 I tried the call buttons again and no dice. Read the schematics and found where the gate switch connected to the control box on top of the car through some molex connectors. Disconnected and reconnected molex connectors just in case the connectors were the issue. No dice. Seems like the microswitch inside the gate switch might have finally died.
I'm not a technician, so I'm looking for one that can work on this unit. I'm technically minded so I can maybe help. Any assistance appreciated.
Last edited by SamirD; 02/22/18 07:23 PM. Reason: forgot to add that I'm not a tech
Open to any ideas or suggestions.
Where are you located?
Hazanko
Hazanko
There should be reputable companies in your area that could service your equipment. I would recommend running the car until it shuts down again, calling a company and explaining your situation. They should be able to tell what switch is open and give you a price to replace it. Good luck
Hi Johnny. Thank you for the reply. I don't know why the forum didn't notify me of it. frown
The elevator is in Athens, Alabama.
There are probably companies, but I don't know how 'reputable' they might be, hence why I'm asking here as you guys would know the good from the bad for sure. (Service on anything in our area seems to have the worst techs--from cars, to appliances, even wayne petroleum fueling pumps or commercial washers and dryers.)
I have a short list of local companies to call, but none of them specifically service Dover (most are actually sales of other brands), and I'm not sure if Nashville Machine can service our area as they are only 100mi away, but I don't know if there's 'territories' for service.
Samir, could you upload a picture of the controller? I'm not sure what a Dover Model IH25 is. I think this might be a Destiny WOV under the Dover brand.
I can. Just let me know where I can find the controller and I'll do it. smile
I also have the spec/cut sheet from the original installation, the installation manual, as well as the owners manual I can email you if that will help.
My email is [email protected] Email the pdfs and I will look at them. Do you know if it is an overhead winder, a roped hydraulic or where the equipment is located?
Thank you Johnny. I just emailled you the documentation I have. It's a roped hydraulic with the oil sump beside the elevator pit on the ground level. The main control boxes and power cutoffs are there too.
What you have is a residential elevator made by WheelOvater for Dover Elevator.
WOV was purchased by TKE Access and is now out of business. There is a company in Huntsville called Homelift. They used to be a WOV dealer and are familiar with your elevator. Their phone number is (877) 643-6210. I seriously doubt that the gate switch needs to be replaced, however, it is a possibility. They used GAL gate switches and they are fairly bulletproof in these installations. If the DC module has the indicator lit, most of your safety circuit is Okay. The problem is that GL module is not active and that could be the stop switch inside the elevator or the gate switch. I would suggest that you call Homelift and have them bring along a gate switch and come fix your elevator.
Those modules are in the upper right hand corner of your controller. The controller is the big grey box 24x24 in the pump area.
Thank you so much Johnny!
I was able to get Nashville Elevator to come out and they were able to come out and take a look. First thing that was found was that the coupling between the motor and pump had a hairline crack and had fractured. That was replaced and then the elevator worked like normal and did the same thing to one of the techs--stopping while in motion. They suspected the door switch contacts since they said the same thing you did about the gate switch being quite bulletproof. Sure enough, two of the door contacts were just not making proper contact 100% of the time. They fixed that by shimming some things and it seems to be working great now.
The tech's from Nashville Elevator also mentioned it was a WOV rebranded as Dover. Good to know there's a company in Huntsville familiar with them if we ever need help again. Even though Nashville Elevator was awesome, I know the bill will be heavy.
I've learned a lot from this experience and lot about our elevator and appreciate this great forum and all your help Johnny! If you guys ever need help with computers, computer networks, cars, or photography, feel free to give me a shout. smile
PHP: 8.3.33 Page Time: 0.026s Queries: 40 (0.006s) Memory: 3.0636 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 23:58:07 UTC
