0 members (), 73 guests, and 2 robots.
#23407 03/13/18 02:29 AM
Hi Friends i'm changed 3 times the igbt six pack module in Tac 50 and Was damage i'm changed all capacitors ,current regulator card ,inverter interface,,QSS/QSR interface card, snubber card , QSS/QSR IGBT ,and DSP Card and the problem continue. Any tip ?
Had the same problem about a year ago. Replaced the IGBT module twice myself. Ended up sending it to aAccess Elecronics. They did an upgrade on the IGBT module and added 2 caps. Been working since.
Ok let me check thanks
Are you using the Dow heat sink compound and a torque wrench?
Of course!
It’s worth repeating!
I just had this issue where I replaced an IGBT and the new one failed the same day. Is there a procedure for how to change them? I did not use new heat sink compound or a torque wrench. I don't work for tke, so I don't have access to their internal documents.
PHP: 8.3.36 Page Time: 0.027s Queries: 28 (0.011s) Memory: 3.0274 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 10:24:35 UTC
