#23416 03/13/18 08:00 PM
20 yr tech
20 yr tech
Hello everybody. Long time reader. 1st time poster. I got an issue with a miprom HS. Doors are intermittently having issues. Either staying full open or not opening at all. In October 2016 my company replaced the door board a p-31737. Not sure how to proceed. Controller is throughout up some Error codes. 45. 96. 87. 95. Not sure what all those are and if they are related. Any thoughts guys?
Thanks.
Elevator tech.
20 yr tech
20 yr tech
Lol. Auto correct.. Miprom. Hs.
20 yr tech
20 yr tech
I rapped on the K5 relay with my pocket screwdriver. And the doors stuttered closed. Believe I may have a bad soldered on relay... Frown face
20 yr tech
20 yr tech
Any one have answers to error codes 45? 84? 21? 1? 85? 95? 96?
45= ss info lost,aux door close contacts open. 84= door open limit stuck on. a 21 occurs any time you are on inspect, or the safety circuit is broken. 96 = door open limits do not match (DO17 and DO3) I would suspect you have a open or close limit issue. Or a bad door board.
20 yr tech
20 yr tech
Thank you so much. I will look further into the door board. Another issue now is something selector related. It is a 2 stop. But at the 1st landing it is saying it is at the 2nd. Running up on inspection to the 2nd it just displays - - on the PI. As well I turned it off inspection to level into the 2nd landing and it level up and past it onto the up final. Actually trapped me up there. Would not level back down on inspection. Had to have another tech come and manually lower me. That was the last straw for my day. Left it on car top inspection in between floors. Headed back in the morning. Any thoughts on that?
I think you need to do the shaft learn again, maybe the position of the lift is loss, or the leveling switch / motor ecoder have problem.
20 yr tech
20 yr tech
Ok. Thanks. I will check into that. All good stuff. I will post what I found ultimately. Or if I have more ques
What color are the plug in connectors wires are connected too? Montgomery/Kone had a connector problem failing intermittently and replaced all the connectors with a kit. I believe the good connectors were black and the bad were orange or green. Have to look but I am sure I have a document somewhere with some part numbers on it.
20 yr tech
20 yr tech
Will take a look. As goes the elevator business, I am just arriving to the job now. To continue troubleshooting. I have a replacement board with me. But that is not gonna matter much if I can not get the elevator back to running status. When I left it, it was lost. And not finding itself.
20 yr tech
20 yr tech
It does appear to have all the new wire connectors. I installed the new door board. And set it up. Learned the open limit etc.. Turned everythig on normal. It leveled down to the 1st landing. PI and Controller both say it is at 2nd landing. No faults.... Any ideas?
Does the car run? If it does your PI needs to changed to reflect the actual floor. Menu 3, sub menu 1 for dot matrix PI. Menu 3, sub menu 2 for seven segment PI. If the car doesn't run check the magnets and sensors for slowdown and lveleling etc; Or you could have a bad FCB Board in the hoistway.
20 yr tech
20 yr tech
Ok. 2 new faults. 87? And 49? Any ideas?
The car runs on inspection only.
20 yr tech
20 yr tech
Anyone have a fault list pdf they can share with me? Email me at [email protected]
These are door faults 49 took too long to close, 87 close door info stuck. Sometimes you have to cycle the doors for the unit to run.
20 yr tech
20 yr tech
Thank you so much. At present the elevator is still at the 1st landing. Pi and controller saying it is at floor 2. We are ordering selector magnets and bipolar switches for replacement. From everything I am reading I personally am leaning towards a bad FCB.. Or FOB board.. But you have to start somewhere I guess. I personally as well believe that the FCB or FOB board maybe the original issue. Due to an experience I witnessed with the door board freaking out(all the lights coming on and going off) alternated by a clicking sound coming from the COP. Which I assume was a relay... I will get back over to that job when new parts arrive. Thank you all for your help on this. I have learned a great deal on these. My company only maintains 3 of them..
Make sure the magnets are polarized correctly if you replace them.
PHP: 8.3.36 Page Time: 0.043s Queries: 48 (0.019s) Memory: 3.0822 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-06 06:04:57 UTC
