#23696 04/05/18 07:55 PM
Slayer
Slayer
Having a leveling issue, some floors are perfect while others are off a quarter inch.No reason for vanes to have moved.Wont recognize learn trip.
Greg1234 #23700 04/06/18 01:17 AM
What do you mean by won't recognize?
Greg1234 #23704 04/06/18 01:44 PM
Slayer
Slayer
Tool says abort , car stops before reaching the needed 0 value at the bottom landing to initialize learn run.
Slayer
Greg1234 #23707 04/06/18 09:59 PM
Try replacing your batt ram chips if it wont take learn run
Greg1234 #23708 04/06/18 10:30 PM
Bump up ntsd tolerance to about 500 and try it. Then set it back.
hotsauce04 #23712 04/07/18 03:13 PM
I Online: Content
When those Dallas RAM chips have been the issue, it has worked for me to just swap the 2. They aren’t bad, just like glitched. Of course I don’t know if this always works.
Greg1234 #23713 04/07/18 03:57 PM
Check and make sure your sensors are clean and dont have hoistway junk and dust. run the car down an inspection and make sure NTB goes lower case IN (menu or module ) M 2-1-3-1 i think then make sure ET1.
Greg1234 #23715 04/07/18 05:05 PM
Slayer
Slayer
Hey guys I really appreciate the help, I will hopefully get it fixed and will reply back with what the issue was, thx a million!
Slayer
Greg1234 #23720 04/07/18 10:40 PM
Only one batram chip is really used, the other is backup. You are leaving the bad one in the backup socket on the board.
Greg1234 #23721 04/07/18 10:43 PM
If increasing your NTSD tolerance does the trick, that is a good indicator that your NTSD vane is the wrong length.
Greg1234 #23745 04/12/18 01:16 AM
Len Offline
---------worn sheaves on machine and cables will cause cable slippage too much slippage throws the hoistway counts..off
Greg1234 #23784 04/17/18 06:31 PM
Slayer
Slayer
Appreciate all the help guys, Len you where spot on, cables are slipping just enough to cause the count to be off.Thanks for your input!
Slayer
PHP: 8.3.36 Page Time: 0.029s Queries: 38 (0.009s) Memory: 3.0510 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 14:47:24 UTC
