#1782 09/14/11 04:37 AM
One of our customers would like us to take care of their Schindler 400As. Do you need a tool to work on this controller or does it have on board diagnostics? Are these controllers problematic or are they fairly solid? Thanks for the help!!
UW BADGER
UW BADGER
V Offline
You not only need a CADI tool you need the CADI with global software. I have worked on many of them with out the CADI (however I adjusted 40 TXR5's wich are similar). They are good equipment as any thing else if its been put in right. The draw back is the big "S" will hammer you on the parts. If you have a very good working knowledge of the TXR5 you should do fine. Good luck.
Vatorman15 #2066 11/18/11 05:25 PM
you need the cadi tool but you also have to make sure the big S soesnt take the simm cards out. they contain all the prgram info. it can run without the simm cards but the first shutdown and rebook will screw it up without the cards.
partspec #2432 01/28/12 03:18 AM
As long as you don't loose the drive and you have the SIMM card you should be fine. Without the card you won't be able to see all the faults or the I/O statices. If you loose the drive good luck, you will need the CADI to set it up.
Schmitty74 #2451 02/01/12 03:03 PM
UW BADGER
UW BADGER
V Offline
Well not really. I've replaced a few drives on the 400A's, the sim contains every thing you need for set up.
Schmitty74 #2453 02/01/12 04:37 PM
Yep..
Vatorman15 #2457 02/01/12 09:46 PM
This is the one I meant to say "Yep" to..Sorry..
LA Elevator
LA Elevator
You will need CADI GC to do that and make sure you have the original sim card. I've purchased cadi gc from this website and it works great: www.liftwares.ir
liftronic #15736 12/30/15 11:38 PM
The biggest regular issue with 400A are the brakes and brake micro switches.The newer Mayr brakes are the answer to that problem but getting them will be hard for another company. All the other stuff about the SIMM cards is true. Cadi is not needed very often unless you wipe out a drive but access to the SMLCD is needed.
Newer software has a back door to give limited troubleshooting but earlier versions don't have that.
Smitty #15737 12/30/15 11:45 PM
Schindler used to deliberately leave a few rather stupid drive settings out on new drives just to make having Cadi a necessity to getting a new drive back up. I too have set many up recently with just the SMLCD.
Smitty #15819 01/08/16 12:24 PM
Having a Cadi is like working with two arms instead of one with just the chip...
Renard #15976 01/27/16 09:13 AM
SORRY GUYS I NEED SOFTWARE CADI SCHINDLER SOMEONE CAN 'HELP ME.
THANK YOU IN ADVANCE
MY EMAIL [email protected]
fottere #16146 02/12/16 11:00 PM
CADI is only fir troubleshooters and specialists working for Schindler!!!
Is there a manual out there for this elevator
Smitty #17055 05/14/16 03:36 PM
V Offline
Does anyone have a part number for the Mayr brakes and where you purchase them? thx
vatormx #17350 06/21/16 03:10 PM
Liftwares sells the Cadi but it is the newer GC version.
does anyone know what the rs232 settings are for this elevator to listen to the status?
PHP: 8.3.33 Page Time: 0.031s Queries: 48 (0.009s) Memory: 3.0788 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 20:24:29 UTC
