#24222 06/28/18 12:14 AM
have a 5-floor kone MRL that on Insp it vibrates bad and when you are on auto it's not to bad 'but know I'm getting brake switch faults. I adjust the switch and it's good for 5 or6 days then comes back in. I'm thinking the vibration from the machine is causing the switches to go out of adjustment. I'm thinking the tach is causing the vibration,
Anyone had a similar problem?
ubro96 #24223 06/28/18 02:31 AM
Replace brake switch they are crappy. How are the rails? Dry rails wreak havoc on them. Bad tachs or encoders will usually show as 108s
ubro96 #24224 06/28/18 01:52 PM
Check brake gap adjustments and set brake switches accordingly. I put a dab of glue on the set screws of the brake switches to be sure they don’t back out. Vibration sounds like you may have a brake dragging on the rotor slightly.
ubro96 #24227 06/28/18 10:23 PM
I think it’s only the V3F25 drives that monitor the main brake. All others don’t even look at it. Check that one is picking good. Make sure the shoes are straight. If it’s kicked, the shoe has separated from the core and the whole thing needs to be replaced. The switch will still pick but the pad can hang up. If they look OK, I would adjust them both with feelers, nice and square. That being said, tach/Encoder is always a good guess for vibrations/shaking.
ubro96 #24230 06/29/18 12:51 AM
Thanks for the input. I've adjusted the main brake I'll try the emergency next and put a new switch on it
ubro96 #24231 06/29/18 01:56 AM
Be sure to get the Low Movement Microswitch
ubro96 #24233 06/29/18 06:46 AM
Since you’re looking around in the hoistway, be sure to check that the rubber wheel is present on the governor encoder. After a few years they can crack apart and come off.
ubro96 #24234 06/29/18 11:15 AM
We just took over a resolve unit that the customer said it had been vibrating for 2 years and the out of town adjuster couldn't fix it. We tightened up the coupling on the encoder and fixed the problem. Sometimes we make things harder than they are.
ubro96 #24238 06/30/18 12:19 AM
if anyone needs a tool to operate the brakes from on top of the car when adjusting let me know
ubro96 #24243 07/01/18 12:34 PM
I took the tach off and made sure everything was tight, took out the brushes and blew compressed air in, put back on and it seems a little better
BillS #24245 07/01/18 04:38 PM
What do you use, the Kone box? I have been using a Variac and a bridge rectifier.
PHP: 8.3.36 Page Time: 0.029s Queries: 39 (0.010s) Memory: 3.0529 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 20:42:26 UTC
