#24235 06/29/18 02:54 PM
I have a question about the load weigher. When I go into menu 5-1 and it shows L 5 with the car empty does this mean it's 5%? From my understanding of these elevators that when you set up rhe load weigher you turn the pot until it reads 0 then load up the car and make sure it's set at 100 then when the car is empty again it should read 0 (+/-3). Am I right on this? Thanks in advance.
Yes 5%. Ideally you want it set at -2/3 at the bottom. Run to the top and it should read fairly close. The Offset pot will set this. The gain shouldnt be touched unless you have the load inside the car. This is assuming you are using the analog VTC board.
Thank you.
BRG Offline
Need to know what drive you have in order to set loadweighing.
PHP: 8.3.33 Page Time: 0.019s Queries: 22 (0.005s) Memory: 3.0111 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 04:36:56 UTC
