0 members (), 27 guests, and 4 robots.
#24591 08/24/18 06:14 PM
TAC 32: After a recent power bump we found all the ( BAD) leds lit on the IOD board. The CPUA board lcd is still usable. It appears that the cpua and Ido boards are not communicating. The error code list indicates a 1921 fault and that one or both boards may be bad. I Just thought I’d touch base here before throughing in the towel. Any help or thoughts would be appreciated. Thanks
Car Fault: 1921
Fault Description:
Safety Processor Not Online - At power up, the CPUA did not detect the IOC/IOD card safety processor communicating over the car CANbus.
Possible Causes:
A defective CPUA.
A defective IOC/IOD.
Check your power supply. Secure your connections. Config safety processor. Check hnbs. Good luck
Thanks Guys. I tried the power supply first thing. No issues. Now I’m just trying to find the boards. CPUA 6300xe1 & IOD 6300acj1. Like findingntutle teeth it seems. Thanks again
You can use an XE2 if that helps in your search.
Thank you Sir!!
20 yr tech
20 yr tech
Any result here?
PHP: 8.3.33 Page Time: 0.029s Queries: 28 (0.007s) Memory: 3.0262 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 07:02:50 UTC
