2 members (RedLunar47, ot1989),
52
Posts: 34 |
Hello I’ve got a fault 0117 on does anybody no the procedure to write parameters back on to drive unit jvop
Posts: 39 |
Dear, Which drive do you have?
Posts: 93 |
0117 is no set up drive fault. You need to do a set up drive.
Posts: 34 |
It’s a yaskawa Drive I’ve been told you it has to see certain mags in the shaft for it to perform a learn run I have tried this when I go into 5-2 it won’t allow me to go to 1 to do a shaft learn any help.....
Posts: 93 |
Need car just below bottom floor with 61u and 30 led,s lit and 61n dark. Set up should begin when you switch back over to normal
