Page 1 of 2 1 2
#24655 09/01/18 09:32 PM
underdog
underdog
I have hydro tac20 nothing works in cop yet I can place car calls through IMS ,elevator functions properly using hall calls , replaced CWID L24 LN board and still can't get cop to work ,no faults logged ,any suggestions?
Rav4guy #24659 09/02/18 08:06 PM
any Status in Car Disgnostic ?
Rav4guy #24660 09/02/18 09:53 PM
underdog
underdog
Only thing main Cop Lon not responding ,no faults though
Rav4guy #24661 09/03/18 03:04 AM
You need IMS and a PCC-10 Lon card or SLTA (Serial Lon talk adapter) and Initialize the LON.
Rav4guy #24663 09/03/18 01:53 PM
underdog
underdog
Thanks Rolly,I have the cable but do you where to get the card from? I searched and is only one website offers selling it ,I was hoping that one of local electronics stores sell them to save time
Rav4guy #24664 09/03/18 04:29 PM
The cards are rare...Get one if you can.
Rav4guy #24665 09/03/18 05:23 PM
There is a USB LON-Talk adapter, I’d get that one so you’re not tied to an ancient laptop. Nothing against ancient laptops, mine still works fine, but I’ll be ready when they finally upgrade.
Rav4guy #24666 09/03/18 09:17 PM
Indirtwetrust. You have to have IMS version that USB adapters work on or he will still need the PCC-10 or SLTA.
Rav4guy #24668 09/04/18 05:45 PM
(Hmmm...some trouble posting, so I’ll try again)
IF by chance your TAC20 uses that stupid pc strip for COP buttons, the ribbon cable connector at the top of the board will often unplug itself enough to loose connectivity. I’ve experienced this on two units over the years. I zip tied each one I had on service.
Rav4guy #24670 09/05/18 12:14 AM
I don’t think the IMS version should matter, there is an adjustment in settings for USB. I got a hold of one, download the driver of the internet, changed the 1 adjustment in settings and it worked. You still need the cable for the Mini-DIN plugs to talk to the host.
Rav4guy #24691 09/07/18 09:02 PM
underdog
underdog
I got hold of one of PCC-10 card but as soon as I open advanced lon computer freezes up and not responding
Rav4guy #24692 09/07/18 09:04 PM
underdog
underdog
I never tried the usb adapter or the cable that will need to go with it, do you have picture of the adapter since online search is giving different types
Rav4guy #24694 09/07/18 11:45 PM
It’s the TP/FT-10. The cable is the same one you use with the PCC-10 card. You just need a little adapter cable that goes from the funky 2 pin plug on the adapter to the 3 pin plug on the old cable assembly. I think it should come with it.
Indirtwetrust #24695 09/08/18 12:26 AM
underdog
underdog
Thanks ,do you know by any chance where to get NXE files?Also the msg I am getting when I go to LON Explorer and highlight main Cop is "waiting for node to respond",is not the LN card is not the LN24 is not CWID board , I went through the connections ,I am very close to call the 188E board
Rav4guy #24696 09/08/18 01:44 AM
What does it say if you put the old LN card back in?
Rav4guy #24697 09/08/18 01:50 AM
You won’t see the new LN in LON explorer until you delete the old one, add the new, find & bind with Advanced LON manager. You should be able to get the file by selecting the channel B in explorer and downloading, it will put the file in the job folder in IMS folder.
Rav4guy #24698 09/08/18 02:08 AM
underdog
underdog
I found an exact job that works with no issues and took the suspected LN board and install and it worked perfectly that is why I know it is not the LN board ,so I install it back in unit that cop is not responsive that is why I didn't need to go through LN replacing procedure
Rav4guy #24700 09/08/18 04:11 PM
I should say that I am far from an expert on LON and don’t work on it very often. But that goes contrary to the way I think of LON working. While you can find a job with an identical cfg file, the nodes have unique addresses, that’s why you have to use the Replace Node, Delete Node, Add Node, Find Node, Functions in Advanced LON Manager. But if that LN worked in another car, and maybe someone else with a better understanding can explain how, I guess you can assume that it’s OK. You probably are going to have to replace the 188e but first you need to rule out the cable. Read LCH1 & LCH2 to ground or the shield, looking for Mohms, unplug the LN and make sure you can read the 188E’s termination resistance from LCH1 to LCH2.
At this point, if the cable checks out, you have to get Advanced LON manager working!
Rav4guy #24701 09/08/18 04:39 PM
underdog
underdog
I was surprised as well to find a job that has an exact LON configuration file and it did work with no problem ,it is very rare!
I will definitely recheck cables again and probably connect LN board directly to 188E bypassing CWID ,travel cable and channel interface board in controller and see if LON starts responding .
I searched about the LONTALK board and apparently there were setting that I needed to change to make it work ,I am going back on Monday to try it again.
Rav4guy #24711 09/10/18 08:47 PM
underdog
underdog
Under channel A or B how do you add Host in LON Explorer? When I search for nodes under advanced LON manager I see the LN but not the host
Page 1 of 2 1 2
PHP: 8.3.33 Page Time: 0.201s Queries: 55 (0.155s) Memory: 3.1136 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-20 21:20:48 UTC
