robot. |
Posts: 1,766 Likes: 11
Posts: 1,766 Likes: 11 |
In Advanced LON Manager, select the correct channel, click Add Node, press the service pin for that channel on 188E.
Posts: 215 |
Channel A is car side, channel B is hoistway. Host is on the 188e card I believe. Been a super long time, but it was find and bind for nodes, and adding hosts was at the card in machine room.
underdog
underdog
Posts: 45 |
Thanks guys I will try that, this has been a nightmare except it doesn't go away when I wake up since I never dealt with LON issues before
Posts: 736 |
You have to press serv pin in Machine room too...
underdog
underdog
Posts: 45 |
I ordered new 188e board which is 6300ky14 and apparently it is compatible with all 188e board as long as I can upload v4r5d software which I don't have ,does anyone have this software?
Posts: 736 |
I made a post on how to set up a lon helping someone out about a year or two ago.. See if you can find it.
underdog
underdog
Posts: 45 |
Channel A was not responsive and ended up being the 188e board and when I ordered a new board they sent me 6300ky14 which requires newer software version v4r5d,I was able to set up LON on new board no problem just the existing software version doesn't support this new board. Do you have ._080000.dat file version v4r5d?
Posts: 197 |
underdog
underdog
Posts: 45 |
Posts: 2 |
Hate to reply to an old post.. I have the echelon USB adapter along with the cable vertical express sells. Am I missing something? I’m assuming I need another adapter just not sure what exactly
