#24681 09/06/18 12:24 PM
Elevator inspection report for a Hydraulic 1967/1970 Dover says that the car emergency lights aren't operational. (check bulbs, battery, and charger)
Where should we look to replace/check these items? A detailed description would be very helpful!
Thank you!
This is like asking the garage how to change window washer fluid.
Was worth a try I guess. Elevators are not my expertise.
Engineer
Engineer
If you don't know elevators, don't be poking around a lift shaft.
This kind of work is not only required to be done by a licensed electrician, but also someone with proper lift training.
Money is better spent on hiring a qualified licensed elevator contractor. If not, you may pay more in fines and legal fees for personal injury and then late state fees on top of that. Heed the above advice.
Thank you!
I would just have an electrician replace all existing lift car lighting units with fully maintained units which will give you about 3 hours of emergency lighting.
PHP: 8.3.33 Page Time: 0.023s Queries: 26 (0.006s) Memory: 3.0189 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 06:43:51 UTC
