0 registered members (), 12 guests, and 4 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#24969 - 10/12/18 01:31 PM OTIS 21 UCL PART
chicago Offline
chicago  Offline
Looking for part number for Otis Generator transfer interlock(walking bar). Keeps K and KR from picking together.
2 types available. Looking for larger part number.
Thanks .
#24972 - 10/12/18 10:11 PM Re: OTIS 21 UCL PART [Re: chicago]
chicago Offline
chicago  Offline
Found part number
#24975 - 10/12/18 11:25 PM Re: OTIS 21 UCL PART [Re: chicago]
workingclass Offline
And it is.... *drumroll* ...
(People search these things)
#24976 - 10/13/18 01:38 PM Re: OTIS 21 UCL PART [Re: chicago]
Rolly Offline
Rolly  Offline
If you check the print K & KR should never Electrically be in together. The walking beam is to prevent blowing a main line fuse in event of a mishap. Always make sure there is condenser timing between the two and all the De-Ionizers are over the large contacts. The De-ionizers also prevent blowing main line fuses buy separating the conductible gas (ozone) created buy arcing when AC is used on Carbon to Silver. Never use Silver to Silver contacts on AC. It welds. Then you would need your walking beam. Otis found that out many years ago when contacts on Escalators welded and unit kept running when safety circuits were opened. Above all be safe!
#25019 - 10/17/18 07:26 PM Re: OTIS 21 UCL PART [Re: chicago]
chicago Offline
chicago  Offline
Sorry guys, part number.......6543E1
#25039 - 10/20/18 04:22 PM Re: OTIS 21 UCL PART [Re: chicago]
Len Offline
Len  Offline
......correct that was present in the old R"series..than a contact was added into the brake circuit ..
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.046s Queries: 15 (0.012s) Memory: 2.6871 MB (Peak: 2.8546 MB) Zlib disabled. Server Time: 2024-06-16 10:00:17 UTC
