#24969 10/12/18 01:31 PM
Looking for part number for Otis Generator transfer interlock(walking bar). Keeps K and KR from picking together.
2 types available. Looking for larger part number.
Thanks .
chicago #24972 10/12/18 10:11 PM
Found part number
chicago #24975 10/12/18 11:25 PM
And it is.... *drumroll* ...
(People search these things)
chicago #24976 10/13/18 01:38 PM
If you check the print K & KR should never Electrically be in together. The walking beam is to prevent blowing a main line fuse in event of a mishap. Always make sure there is condenser timing between the two and all the De-Ionizers are over the large contacts. The De-ionizers also prevent blowing main line fuses buy separating the conductible gas (ozone) created buy arcing when AC is used on Carbon to Silver. Never use Silver to Silver contacts on AC. It welds. Then you would need your walking beam. Otis found that out many years ago when contacts on Escalators welded and unit kept running when safety circuits were opened. Above all be safe!
chicago #25019 10/17/18 07:26 PM
Sorry guys, part number.......6543E1
chicago #25039 10/20/18 04:22 PM
Len Offline
......correct that was present in the old R"series..than a contact was added into the brake circuit ..
PHP: 8.3.36 Page Time: 0.030s Queries: 26 (0.010s) Memory: 3.0192 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-06 14:37:32 UTC
