#25167 11/09/18 01:19 PM
Is there anyone out there that has put a new TKE HDLM door operator on an existing DMC? The new operators come with the PA6 Universal Door Board and a UIT. I know that it can be set up for 485 communication. However, I am unsure if they will talk or not. As always, Vertical Express and TKE are of no help at all.
Knoxville18 #25168 11/09/18 04:59 PM
Tke has their new door operators that will work i believe. Ld16 operators. Never removed a dmc door operator. Just replaced the board since it communicates with everything such as the clc and selector.
Knoxville18 #25169 11/09/18 06:23 PM
I believe for the DMC you need to use a PY2 or PY4 board. I don't believe the PA boards will work.
Knoxville18 #25170 11/09/18 09:44 PM
That is not going to work.
Knoxville18 #25171 11/09/18 09:46 PM
I was talking to someone about this yesterday. I suggested you order the FX2 board on eBay for $200
Knoxville18 #25172 11/11/18 03:00 PM
Thanks for your input everyone. My problem is that we installed one HD/LM operator already. I know that the mechanical parts to the operator are very similar, could I switch the PA door board out for a PY or the FX2 board you are suggesting? What I am not sure of is that the PA operator has a VFD drive in it and runs a three phase AC motor. Are the PY or FX boards capable of running an AC motor? Or do I need to replace the motor with a DC motor? Vertical Express suggested installing an HD85 operator instead. I suppose I am wondering if I should just re-install the old operator, return the HD/LM operator and purchase the HD85 instead. This is the price I pay for not verifying the proper job number on the survey.
Knoxville18 #25173 11/11/18 04:33 PM
Are the PY boards available from Vertical express? I was under the impression this was because they were back ordered or something. You should be able to make this work with a PY4 board and a 1/6 HP DC motor and encoder. The part number for the motor with the correct encoder is 9841775. You also need the capacitor that goes under the door board.
Knoxville18 #25175 11/12/18 12:09 PM
I will check today. I think Sees sells them as well...normally a bit pricey. It doesn't hurt to give it a shot. Thanks for the input.
Knoxville18 #25507 12/31/18 01:10 AM
Send that operator back and just replace bad board
Knoxville18 #34857 03/04/23 01:06 AM
Did this ever work?? Haha
PHP: 8.3.33 Page Time: 0.022s Queries: 34 (0.006s) Memory: 3.0424 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 19:21:54 UTC
