0 members (), 15 guests, and 4 robots.
#25179 11/14/18 07:36 PM
Hello. I got a gen 2 stuck in between floors with gov over speed switch out. I can not reset it. I tried with manual reset on controller and by hand at top of shaft. The tiny black cam wants to pull back away from switch. Please help
Please help ? No One has procedures to reset governor ?
Before the manual reset button will do anything, you need to enable the reset function using the handheld tool.
However, the actual switch is a little white plastic disk that sits behind the governor sheave.
If you get get to that, you're golden.
I was there. I flipped it up. But tiny cam still spring loaded to push back away from switch
Does anyone have procedures to reset ?
I might be mistaken, but perhaps the spring loaded black actuator and the microswitch have nothing to do with overspeed. It's just a thought.
Put on insp use tool go to M2251 go on to gov reset enable it then hold reset gov switch for 5 sec or so
Your activating an I/O with tool to operate a solenoid. You can also use a jumper energize the coil to reset. Check your wiring diagrams.
PHP: 8.3.36 Page Time: 0.027s Queries: 30 (0.009s) Memory: 3.0312 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 12:46:53 UTC
