#25350 12/05/18 06:55 PM
S Online: Sad
Hello. I have a problem on GEN 2. Although changing EFO - P paramater as 2, the elevator travels 1st floor. Could you help me. Thanks.
Do you have a floor below 1st? Basement?
I think you need to change EFO-CK too.
S Online: Sad
We have basement. Floor names are -1,0,1,2,3. thanks
S Online: Sad
There is not EFO-CK parameter. Could be a diffrent name of it. Thanks.
Where do you want it to recall to
S Online: Sad
we want to recall to "0" floor. Also the controller is GCS 222.
Best regards.
M 1-3-1--6 on tool which is emergency, then go on 26 times to EFO-P landing 1-64 is front doors
landing 101-164 is rear doors
landings 201-264 is both doors
also Next is EFO-CK Change to match EPO-P
after changing Do a reset M 1-5-1
should be good
S Online: Sad
I didnt find the EFO CK
I will check again. Thank you. Best ragards.
It should be right after EFO-P.... do you have a blue tool that is unlocked?
Have you changed EFO-P to 1 then blue enter. Then clear ram m-1-5-1. Then tried it?
S Online: Sad
thank you very much. I will make your advice. the elevator is in another city and far away. it will go 2 weeks later. best ragards
PHP: 8.3.36 Page Time: 0.034s Queries: 38 (0.010s) Memory: 3.0507 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 06:52:15 UTC
