Posts40,945
Hi,
Recently after performing a governor trip test on a Gen2 GCS 222, the lift will not drive on inspection toc.
It will drive on ERO on the E&I Panel.
Otis tool also sees that its on INS as well as the screen in the e&i panel.
Car door veins also engage when trying to drive from toc inspection.
The e&i panel screen also says PCS is not enabled and has a cross, could this be the issue? Or it could be a paramater maybe?
Though I did see what looks to be water damage on amd around the Wago plugs in the E&I panel so possible this is the cause.
It worked fine only until the governer trip test.
Cheers!
John Reynolds
John Reynolds
Justed PM you.
PHP: 8.3.33 Page Time: 0.024s Queries: 18 (0.004s) Memory: 2.9982 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 19:01:38 UTC
