1 members (Indirtwetrust),
47
Hackmaster
Hackmaster
Posts: 10 |
I have a Otis Mrs w generator just put in a new hoist motor got the car runs up normal speed but slow speed in the down the generator sounds a little bogged down on the down.chexk all speed relays etc Any help would be great
Posts: 736 |
Sounds like a ground or leak in loop circuit.
Hackmaster
Hackmaster
Posts: 10 |
Thanks for your quick reply I opened the the top where the connections on the genny was and it was litter w carbon dust.how can I research the leak .just send the generator out?
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
What was the original problem with the motor? Also make sure you are getting full field voltage to the motor. You check for leaks with a megger.
Hackmaster
Hackmaster
Posts: 10 |
Orig prob w motor is that they pulled the motor due to a broken pig tail and the com was cooked.i check the MF runs constant at a standing of 40 and running around 85 in both directions. Thanks for your reply
Posts: 194 |
compounding might be screwed up,neutral might have been moved on generator..up/dn.should have a flat of 10fpm..
Hackmaster
Hackmaster
Posts: 10 |
Great thanks for the help
It’s a good idea to check neutral first. Even if the motor/gen just came from a motor shop. You’d be surprised.
Hackmaster
Hackmaster
Posts: 10 |
