#25548 01/06/19 12:54 AM
Hackmaster
Hackmaster
I have a Otis Mrs w generator just put in a new hoist motor got the car runs up normal speed but slow speed in the down the generator sounds a little bogged down on the down.chexk all speed relays etc
Any help would be great
upndn33 #25549 01/06/19 12:55 AM
Sounds like a ground or leak in loop circuit.
upndn33 #25550 01/06/19 01:02 AM
Hackmaster
Hackmaster
Thanks for your quick reply I opened the the top where the connections on the genny was and it was litter w carbon dust.how can I research the leak .just send the generator out?
upndn33 #25551 01/06/19 01:14 AM
What was the original problem with the motor? Also make sure you are getting full field voltage to the motor. You check for leaks with a megger.
Indirtwetrust #25552 01/06/19 01:21 AM
Hackmaster
Hackmaster
Orig prob w motor is that they pulled the motor due to a broken pig tail and the com was cooked.i check the MF runs constant at a standing of 40 and running around 85 in both directions.
Thanks for your reply
upndn33 #25561 01/07/19 02:43 AM
Len Offline
compounding might be screwed up,neutral might have been moved on generator..up/dn.should have a flat of 10fpm..
upndn33 #25563 01/07/19 02:54 AM
Hackmaster
Hackmaster
Great thanks for the help
upndn33 #25568 01/07/19 11:21 PM
It’s a good idea to check neutral first. Even if the motor/gen just came from a motor shop. You’d be surprised.
upndn33 #25569 01/08/19 12:27 AM
Hackmaster
Hackmaster
Will do ty
PHP: 8.3.36 Page Time: 0.029s Queries: 32 (0.010s) Memory: 3.0337 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-06 14:36:09 UTC
