S Online: Sad
can you help about how can I connect, which cable I must use, pinout and configuration.
TAC-50 CPUA-2C
Thank you.
Is it a TAC50 Card Rack or a TAC50-04 with a CPUA (32Bit) or is it a TAC50-04 186 CPU (16Bit)?
S Online: Sad
I have upload board. this is Korean board and called CPUA-2C. Thank you for your help.
https://ufile.io/2bjsf
It looks just like the US version of the CPUA (even same part number) , but not sure about fan. Anyway, you can use a 9-pin serial cable with the black IMS icon, or a USB cable with the red IMS icon.
S Online: Sad
Is it right screen.
https://ufile.io/7zx7k
It appears to be the right screen. You can right click on the Net01 and rename it. Then right click on it and add the Group and then right click on Group and add cars.
S Online: Sad
I connected as you mentioned. But I can not find the window that can be given command.
https://ufile.io/67360
Select the car, then go to the service menu. Remote Fast is for entering commands, Input/Output will show your I/O map, Morion diagnostics will show you the status of your car.
After you rename you need to close and restart IMS..
S Online: Sad
There is not Service Menu. file, monitor, traffic,events,view,window and help are ok. I did not solve.
S Online: Sad
Also car bus has not connected to the controller yet. Can be the reason why not displayed of service menu. thank you. you are so helpful and open my mind.
S Online: Sad
Also the controller is TAC-50K.
PHP: 8.3.36 Page Time: 0.030s Queries: 38 (0.011s) Memory: 3.0507 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 06:51:43 UTC
