#25699 01/18/19 07:03 PM
I am trying to figure out how to run an Otis 411 in "test" mode. I want to be able to remove the car from group and shut doors off. have a blue tool and assume it is done thru it. I have looked for this for a long time. Thanks for all your help.
You can run the car off of the mlb board by removing the communication cable going into the ocss board . All commands would have to be given from the service tool at that point and it would have to be plugged into the mlb board .commands would be given in M-2-1-2 menu. You can also force the car hall cutout switch on in the M-1-3-2 menu parameter 2489 I believe. You’d still be able to run the car from your ocss board and it won’t answer hall calls just car calls . It would still respond do group functions like fire recall, etc.
2489 and 2490
PHP: 8.3.36 Page Time: 0.026s Queries: 20 (0.009s) Memory: 3.0049 MB (Peak: 3.5932 MB) Data Comp: Off Server Time: 2026-11-06 00:30:58 UTC
