Had a flood. Water damage to universal door control board on top of car. Is this board a drop in replacement? Will I have to do any programming with IMS on the new board ?
You will need to setup the board. There are manuals on vertical express that are useful.
Vertical express will not give me set up procedures Does any one have them ?
the website has a list of operators with setup instructions. You can download one that fits your needs. You will need software based on your door configuration. If you have a operator with a UIT I have swapped boards, the software is retained and a few parameters and your in business. If it's a operator without UIT you will need IMS and software.
I have IMS but no software
Order a NEW door board, should be a 6300PA6, a 6300HL1 UIT and the 6” ribbon cable part #9863295. You can do it without the ribbon cable but it makes it a lot easier. The NEW door board will come with V2R24 generic software and has the profiles already loaded and accessible through a new menu called Config or something like that. So you can just plug it in, pick the right profile from the UIT, save to flash, do an autonull and a scan, turn it off, pull the UIT and keep it for the next time. You should be in business.
They gave me part number 980377 door operator board. This is the board that fits the motor . There is no UIT
When you order the board you would order the UIT seperate.I would get it since the door operator UIT can be used from job to job, easier to carry than a laptop.
I tried to do it with out the UIT . But my ims would not get into the door diagnostics smart fast . It said only DMC II .
So I ordered the UIT. will I be able to do everything from the UIT interface ?
If you have IMS and it was installed correctly there should be an icon on desktop called UDC Fast. You use a Thyssen (RS-485) Orange cable to plug into board on top of car. You must also change the serial port driver to ACPI before trying to connect to door board.
I think it does say DMC-II. It kind of is. I think that’s what the Tac20 was going to be called before Thyssen bought Dover. But you can do everything from the UIT.
Tac20 should be a 6300py3. Which replaces a py1. All you need is the uit like dirt mentioned
PY is the old style like a DMC, no UIT. Newer TAC20’s came with PA boards or “UDC”
Vertical express send me the ribbon cable only. No UIT . Now they tell me UIT interface takes months to ship .
Bummer, you can borrow one off of another door operator with UIT or a 10K drive.
Is it Linear or harmonic? Left or Right Hand? AC or DC Motor?
Never mind, I thought I had a PA6 with V2R24 on the van. I was going to figure out how we could hook up 4 buttons to the board, number them 1,2,3,4 and give you a “code” that would select the right profile.
Does anybody have a UIT I can borrow or buy ?
PHP: 8.3.33 Page Time: 0.034s Queries: 50 (0.008s) Memory: 3.0810 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 13:19:10 UTC
