0 members (), 32 guests, and 1 robot.
Posts40,945
#26175 03/11/19 09:11 PM
mar
Getting intermittent insufficient DC loop current feedback faults any ideas already adjusted tp3 test point to ground for 0 millivolts changed scr pri
board
mar #26176 03/12/19 12:26 AM
Check the brushes, rigging, & connections
mar #26284 03/23/19 02:22 AM
mar
Changed scr pri board right above drive and p4 relay my problem has home away
mar #26301 03/25/19 06:52 PM
mar
Correction that was the pt4 relay right next to my scr pri board causing all my intermittent problems
mar #26353 03/31/19 01:41 PM
Motor field voltage will also cause this. Try bumping voltage up slightly, also a current sensor going bad will cause this.
PHP: 8.3.33 Page Time: 0.031s Queries: 24 (0.011s) Memory: 3.0127 MB (Peak: 3.5898 MB) Data Comp: Off Server Time: 2026-09-22 15:58:31 UTC
