Posts41,073
Posts: 2 |
I have a 311 gem with a drive flashing !B1A Also the fault on my service tool says precharge dc low Can’t find what this means can someone help Thanks
Engineer
Engineer
Posts: 281 |
After a full power down and reset of the MCSS, does the fault still exist?
Posts: 262 |
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
Most AC drives charge the DC buss through a resistance of some sort until it reaches a set voltage where the resistance is bypassed to fully charge the buss. Otis calls this precharge and once the parameter M1 pick V PU is reached, the M1 contactors in the drive picks to bypass the resistor and charge the buss all the way.
Posts: 1 |
Currently dealing with this same issue. I replaced the 4 capacitors as a starting point but to no avail. Any tips?
The drive needs to be sent out for repair.
Posts: 81 |
I can get these rebuilt. PM me with pics of data tag for quote.
Posts: 220 |
Access electronics out of Waldorf MD does a good job on these. I have replaced several of these over the years. 301 -645-1733
Posts: 1 |
!B1A i need your help to solve this problem There are almost no parts left on the power floor that we haven't replaced, but the fault continues.
