Car takes calls but then will sit with doors open,never worked on this stuff before
How do you exit the “stuck” mode?
Car on IND?
Do calls cancel?
Stuck DOB?
Stuck PE? Try bypass button if provided. Or SE staying made?
Short of the above, you’ll need prints or someone who knows the numeric relay ID/function for call canceling or door open time.
I got it,idont know the numbers just 41 anf 29 had a bad door close limit.car would take all calls but sit with doors open after a run.
Len Offline
sounds like you are not dropping the 44 relay (Door Open)
status of STE relay up unless edge is tripped or stuck Door Open button
Door Open timer 70T..has a timed rc..Relay has to drop out ..delayed drop after door reaches fully open usually 3 to 8 seconds..adjustable.when doors reach fully open dol limit breaks.energizing DFO relay.
DesertVatorMan
DesertVatorMan
IWestinghouse linear operator ? Check micro switches. OR Some had MAC operator... again check operator micro switches.
I an send prints if you need.
PHP: 8.3.36 Page Time: 0.056s Queries: 24 (0.021s) Memory: 3.0147 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-06 14:34:05 UTC
