Page 1 of 2 1 2
Has anyone tried to put the terminal emulator software for IMC CRTs on a laptop? Motion sent me to Ericom website but couldn’t give me much more info. The only Emulator on there that matched one of the ones listed in the original Computer Peripherals manual was WY-370 so I downloaded the trial for that. So far so good. Now I need to convert a 9 pin Dsub to an RJ11 plug. Does anyone know the pin out for this? There is an RJ11 to 25 pin diagram in the back of the old peripherals manual so I think I’m going to try that with a regular 9 to 25 pin adapter only not actually use the adapter, just wire from the 9 pin to RJ11. Any input on this would be appreciated.
Depending on the vintage you probably want Tiger Term/WY-360. I can email you the program and easy to setup.
Sure, that would be great. What about the DB9 to RJ-11 pin out? And have you got it to work with a USB to serial adapter?
I'm interested in this.
Pm me your email. Yes I does work with USB adapter.
I did
I sent you fellas a Dropbox file
I got the DB9 female to RJ11 cable from MCE today. For anyone who’s interested, here’s the pin out.
RJ11 pin 2 to DB9 pin 3, RJ11 pin 3 to DB9 pin 2, RJ11 pin 5 to DB9 pin 5. Then pins 4, 6, & 8 are jumped together on the 9 pin end.
Would like to have a copy of tigerterm too if anyone can share.
Thank you Turbo6
I just sent a request
Thanks Turbo6
Has this worked for you guys? Meaning you have tested on controller
I haven’t got a chance to try yet
So I finally got a chance to try this today. It works perfectly! I found a document with the exact settings so I’d already set it up. So today I plugged it in, opened the program and immediately got the MCE start screen. I was sure I’d have to mess with something.
Thanks a lot to Turbo6. Tiger Term and the other one MCE recommended required buying a license.
If anyone wants the setup document PM me.
Good to hear👍
TC7 Offline
Thank you!
I sent a request a couple of times (mailbox.org address) but no one approved frown
Workingclass...
Resend
Page 1 of 2 1 2
PHP: 8.3.33 Page Time: 0.031s Queries: 55 (0.009s) Memory: 3.1145 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 00:46:40 UTC
