0 members (), 17 guests, and 1 robot.
Page 1 of 2 1 2
#26616 04/17/19 12:53 PM
hello !!!!
question any one has been used a Cadi
in a controller without SIM ?
to use the Cadi need the SIM ?
NOTIME #26620 04/17/19 03:02 PM
Engineer
Engineer
I could probably test this out for you, I have a spare s5500 main print that I could power on and take out the sim.
I'll test it out tomorrow and get back with results.
NOTIME #26625 04/17/19 05:04 PM
thnks
NOTIME #26638 04/18/19 12:53 AM
Engineer
Engineer
So I tried it, but on a board with nothing on it besides a CGIOF board attached, and cadi didn't load.
Can I ask with youre trying to connect without a sim?
NOTIME #26640 04/18/19 09:53 AM
S Online: Content
I have been told that the "S" folks remove the sim card when they lose the maintenance.
NOTIME #26643 04/18/19 12:33 PM
I have used the Cadi on controllers without SIM cards.
NOTIME #26644 04/18/19 05:31 PM
Check PM
Engineer
Engineer
Not true
True,
the SIM card is a tool (" big S property")
when they sell a controller the SIM card is not in the contract (unless has a special negotiation)
i been use the CADI but only with SIM card , i never did without SIM
so some say yes, some say no
new TX versions has lot of function to access without SIM, but old vercions even KFM (door Disable) is not available
O
O Online: Content
I have CADI GC software, someone could tell me the cable that I need and where to connect it on which board to connect it.
NOTIME #26696 04/23/19 02:12 AM
Engineer
Engineer
If you don't have a serial plug on your laptop, you can get a USB to db9 adapter cable, and then you'll need a NULL MODEM cable to connect from the CGIOB board.
O
O Online: Content
Thank you!!!
NOTIME #26748 04/26/19 07:19 AM
good morning every one, can you help me how to get it
thank you very much
NOTIME #26835 05/03/19 11:54 PM
You can use Cadi without controller sim cards. In fact my first drive replacement on a 400A I did without sim cards. It is a pain and you quickly need to learn to send telegrams to accomplish simple commands, but I did it. It really is your only recourse without the software that uses the UNTR command
NOTIME #27101 06/02/19 06:57 PM
I also have several I use it on without card and it is manageable
NOTIME #27178 06/13/19 04:15 PM
Tell the customer to buy the SIM. These idiot building owners who have no idea what they are and aren't buying when choosing a proprietary elevator to install is comical. I'm even more baffled at the independent companies that take on these buildings for service without the capability to successfully or competently provide the service
NOTIME #27392 07/12/19 12:55 AM
You can use CADI without a sim card. I had to do it myself.The problem is to do a lot of the basic things you will need to learn telegrams. Since there are seemingly a million of them, it can be daunting. I had a couple units in which I had to commision the drive without the sim cards.
It can be done.
NOTIME #27413 07/13/19 11:55 AM
""The problem is to do a lot of the basic things you will need to learn telegrams""
what this mean?
use a hyper terminal?
NOTIME #27421 07/15/19 01:47 AM
Hyper terminal in place of cadi...wishful thinking.
NOTIME #28726 02/16/20 12:46 PM
Hey guys, do new controllers not come with a SIM card? I do installs for Schindler and have not seen one, are they supposed to be in the slot behind the esm display?
Page 1 of 2 1 2
PHP: 8.3.33 Page Time: 0.032s Queries: 55 (0.011s) Memory: 3.1127 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 18:25:29 UTC
