#27089 06/01/19 01:49 PM
Had power problems in building. Had bad selector board and clc. Replaced both boards are trying to set up. When trying to do a hoistway setup I get selector error 005. Door zone reed not true when expected. Anybody have this problem before ?
Jluff #27090 06/01/19 03:54 PM
Did you plug the DZR reed switch back in after replacing the selector board? It’s a 2 pin white MTA plug, goes on CS8.
Jluff #27144 06/06/19 03:55 PM
I know. If you run it down all the way on inspection on to final. Down all the way. Open selector. They will be a red light blinking. Press the button light should stop blinking and stay on. No run up all the way non stop to top limit on inspection. Till it stops. Then take off of inspection. Car should level down light in selector should be blinking again. It should level down and open the door. And should be good to go. You can also learn shaft with the plug in tool from world electronics
Jluff #27149 06/08/19 05:39 PM
DesertVatorMan
DesertVatorMan
very possible DZ reed switch failed.
{{in the
identification of the source of a rash of unexplained DMC Door Zone Switch failures.
The fault recorded is Selector Fault 006. This is a critical fault that takes the unit out of Service.}}
Reed switch had a tech report to replace with new design about 10 years ago.
PHP: 8.3.36 Page Time: 0.038s Queries: 22 (0.009s) Memory: 3.0107 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-05 21:47:01 UTC
