Posts41,073
Posts: 16 |
Hi, anyone please can help me with this. I spend day trying to find what is causing this error code the elevator run a minute sometimes 2 hours but always have the fault code 166 . Kone 831
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
I have Oil Level Low In Tank or Releveling too fast for traction products. K486 relay drops while car is leveling with doors open.
Posts: 16 |
Thanks i read that on the fault manual. i try to adjust the parameter 5:20:9 and when i put that the display show Jpr. Someone knows what Jpr mean
Posts: 270 Likes: 2
Posts: 270 Likes: 2 |
It means you have to move the jumper or the switch on the ADON board and cycle power to change that parameter.
Posts: 16 |
Thanks, i was not cycling when i move the jumper. Thank you
Posts: 16 |
Still the elvator has the same code 166, i was thinking yhe addon board was bad but i test it on another kone and run fine. I have more than a week doing test and nothing. Any idea?
Is it a Hydro or traction?
Posts: 16 |
Posts: 1 |
Was there any resolution to the 0166 fault? I’m having the same issue right now sometimes I’ll get the 180 fault too.
