1 members (BRUCE91), 24 guests, and 4 robots.
Posts41,073
#27632 08/20/19 07:03 PM
Hi, anyone please can help me with this. I spend day trying to find what is causing this error code the elevator run a minute sometimes 2 hours but always have the fault code 166 . Kone 831
I have Oil Level Low In Tank or Releveling too fast for traction products. K486 relay drops while car is leveling with doors open.
Thanks i read that on the fault manual. i try to adjust the parameter 5:20:9 and when i put that the display show Jpr. Someone knows what Jpr mean
Jumper
It means you have to move the jumper or the switch on the ADON board and cycle power to change that parameter.
Thanks, i was not cycling when i move the jumper. Thank you
Still the elvator has the same code 166, i was thinking yhe addon board was bad but i test it on another kone and run fine. I have more than a week doing test and nothing. Any idea?
Is it a Hydro or traction?
Traction
Was there any resolution to the 0166 fault? I’m having the same issue right now sometimes I’ll get the 180 fault too.
PHP: 8.3.36 Page Time: 0.032s Queries: 34 (0.010s) Memory: 3.0428 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-07 04:24:00 UTC
