#27735 08/29/19 11:41 AM
improving the trade
improving the trade
I am having troubles with an 1994 Otis LRV5L. this is a two stop, one opening elevator. to the best of what I have observed, this is what is happening. in the up direction coming into the floor, The UL1 hits the first magnet and drops UMV, then when it hits the second magnet and "releases" the UL1 input sensor ( light drops out in the processor), the processor doesn't always drop ULV (output), the elevator continues to run up level until it breaks the up directional. this kills all the up logic and the elevator levels down. then shuts down, light comes on to exit the elevator and the elevator travels to the 1st land and lets the passenger out.
I have refurbished the mother board and the power supply. this is a daily problem and looking for some advise.
thanks
Detroit City #27737 08/29/19 01:47 PM
Liscensed Journeyman
Up level sensor stuck on
Detroit City #27752 08/30/19 02:57 PM
Maybe a long shot, but could it be the valve allowing the car to be pushed up to the limit? I’ve seen tight packing and maladjusted “up stop” settings behave in the same way as your description.
Detroit City #27756 08/30/19 10:55 PM
improving the trade
improving the trade
im pretty sure the mother board is still sending an up signal and up level output to the relay board after we pass the floor
Detroit City #27760 09/02/19 01:27 AM
Move the directional up 6" to rule out a valve issue. As long as it hits limit before stop ring, you're good. Adjust transition so it has more leveling
Detroit City #27761 09/02/19 01:28 AM
Pretty sure? It either is or isnt. Gotta figure that out first
Philly #27775 09/04/19 03:36 PM
Yep...my thoughts exactly.
Detroit City #27778 09/04/19 08:16 PM
No wiring diagram number posted so, not sure if this job has Leveling 6098 Mechanical Switches or sensors for floor level?
Detroit City #27795 09/08/19 08:18 PM
improving the trade
improving the trade
To All I was real busy last week and finally got back to the site, I moved the directional up and this is not a valve problem, PM and ULV is energized, another question was switches, I forgot to get the wiring diagram number, but this has sensors not mechanical. both sensors replaced, So what happens about every tenth running up to 2nd floor, (top) in the up direction coming into the floor, The UL1 (sensor) hits the first magnet and drops UMV, then when it hits the second magnet and "releases" the UL1 input sensor ( light drops out coming into the processor), the processor doesn't always drop ULV (up level valve output), the elevator continues to run up leveling speed (PM and ULV outputs on) until it breaks the up directional. this kills all the up logic and the elevator levels down. opens the doors, then closes the doors, a light comes on in the cop to exit the elevator and the elevator travels to the 1st landing and lets the passenger out. its seems like its a mother board problem. not that many inputs and outputs involved in this up travel process, does any body have a functional LRV5L ( E8121DB1 ) board?
thanks
Detroit City #27798 09/09/19 03:21 AM
Change the RBI Board in Machine Room. Lot of problems with those boards.
PHP: 8.3.36 Page Time: 0.034s Queries: 34 (0.012s) Memory: 3.0448 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 13:59:14 UTC
