2 members (RedLunar47, ot1989), 52 guests, and 2 robots.
Hi,
I got problem with Shindler hydraulic elev 330A.
The elevator does NOT run in Normal or inspection and the screen shows: "Block ready UNV"
We replaced the main board and the GCIO360 and the problem still same.
We did a hard reset and nothing works.
Anyone can help please? Or has an idea what is going on?
Originally Posted by EMEEL LLC
Hi,
Fault Log ?
Yes, fault log and the usual checks, ie. safety devices, door locks, limits. It will say UNV until the controller is satisfied with all the important inputs. Try to get it running on inspection first.
thank you for your reply
BUT NO fault log, everything looks okay BUT it will NOT run?!!!
All safeties are okay and the door locks, and No error in the fault log.
EMEEL
When you check your error codes are you going to both show and show all. Ive had faults show up it either one while the other was blank. Though im not sure why
I had a similar problem. I had to send the car station I/O board in for repairs.
PHP: 8.3.36 Page Time: 0.030s Queries: 28 (0.009s) Memory: 3.0287 MB (Peak: 3.5928 MB) Data Comp: Off Server Time: 2026-11-06 02:06:23 UTC
