10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#27885 09/25/19 12:28 AM
Anybody have problems with losing zero point on these for tac32 mrlh?
lowoil #27887 09/25/19 11:22 PM
TC7 Offline
Yes, it can be a problem sometimes. Try to get the zero point as close to zero as possible, ideally under 30 millivolts. For reoccurring problems, it may be necessary to replace null sensor, PN #9865901. It is usually necessary to land the car on pipe stands and depressurize system, loosen vic, and shift muffler over to get clearance to be able to slide null sensor off of valve stem to swap part.
It is also worth noting that there is an up and down pilot filter screen in valve block, located under large hex head bolt heads. You can remove these to clean them when the system is depressurized. But do them , ONE AT A TIME as they are very easy to reinstall backwards because they look so similar, (example accidentally putting up screen in down side)
lowoil #27888 09/26/19 12:42 AM
Ive been there and done that,even replaced valve 3mo. ago,del con board, power supply.
lowoil #27889 09/26/19 01:27 AM
TC7 Offline
I haven't been in the situation where the issue can't be resolved. I noticed that the proximity of your hex wrench to the null sensor even effect the reading. I'm curious is this unit one of the earlier ones where you had to add the suppressors around the valve coils?
PHP: 8.3.37 Page Time: 0.030s Queries: 22 (0.010s) Memory: 3.0140 MB (Peak: 3.5946 MB) Data Comp: Off Server Time: 2026-11-25 01:51:14 UTC
