Posts: 3 |
I have a KCM831 giving me a 83 fault. I've tried to learn the hoist way but the CPU will not continue once 30 comes high. Any suggestions?
Posts: 1,766 Likes: 11
Posts: 1,766 Likes: 11 |
Does the car run normally on inspection? Is 61U coming on before 30? Are all your 77 switches in the correct state? Are you getting any other faults?
Posts: 3 |
Car runs normal on inspection from controller and car top. 77 u/n, 77s stays high, switches are good. 61 u/n comes up like it is supposed to. No other faults now.
Posts: 3 |
77u/n function as they should. 77s stays high constantly.
Posts: 13 |
Do the 61 u,n and 30 turn on off at the floors? Is your 77 u and n magnet distance correct from your terminal floors? When your parameter for speed is set for your drive i belive that the distance of your 77 switches need to be correct or shaft learn cant be done.
