#28121 11/05/19 05:22 PM
Elevator Tech
Elevator Tech
I have a three car group Dover ibm relay with a group controller also has card reader which has been deactivated cars 1 and 3 are running fine car 2 having issues stopping on all floors and not opening doors example if on 6th floor give a car call to basement elevator will stop at all floors and not cycle doors then will take off and do this on every floor until gets to basement then opens the door does the same thing in the up direction
Amullark #28122 11/05/19 08:00 PM
Is it stepping correctly while doing this? Does it get to high speed before stopping at the next floor? And it does open the doors at the floor with the call in, correct?
Does it do the same if the dispatcher assigns it a hall call?
Amullark #28123 11/05/19 08:35 PM
Elevator Tech
Elevator Tech
Have not verified the stepping . Will double check for high speed but believe it is . Yes it does open the doors for the floor that the call button was pushed . Doesn’t matter if I hit the car call in controller or hall call in the group controller
Amullark #28124 11/06/19 12:16 AM
I’m struggling to see a way for the car to both make a normal slowdown & stop but not open the doors since the door open circuit obviously work. CS Relay is what drops high speed but it also arms the doors to open. Are the stops indistinguishable from a normal run or does it overshoot or come to a full stop then recover into the floor?
Amullark #28125 11/06/19 12:21 AM
Wait, this isn’t a traction car is it ? (composite). I assumed WCR hydro.
Amullark #28126 11/06/19 01:42 AM
check the 2LR relays
Amullark #28127 11/06/19 03:07 AM
Sorry meant the LR relay(s)
Amullark #28129 11/06/19 10:26 AM
Elevator Tech
Elevator Tech
Yes this is a traction car does don’t overshoot floors
Amullark #28130 11/06/19 11:57 AM
Elevator Tech
Elevator Tech
Sport that was my bad thought I had put composite in there it’s a traction 6 stop with basement
Amullark #28132 11/06/19 12:19 PM
Elevator Tech
Elevator Tech
Dam spell check that was sorry not sport
Amullark #28134 11/06/19 09:20 PM
This could make a little more sense with a Composite. You almost have to be picking CS to initiate a normal slowdown but unlike a WCR, CS does not directly initiate a door open. In this case UC, CC, DC call transfer contacts pick CS and and they also pick CR which picks CST. CST initiated an auto open. So anything that caused CS to pick but not CR like a crossed up or shorted contact on N/O UC, DC, CC, or V in the CS coil circuit. Just to give you somewhere to start.
Amullark #28245 11/20/19 11:52 PM
Elevator Tech
Elevator Tech
Thanks indirt very helpful much appreciated it ended up being a bad relay on V1 thanks again for your help
PHP: 8.3.33 Page Time: 0.035s Queries: 38 (0.011s) Memory: 3.0505 MB (Peak: 3.5918 MB) Data Comp: Off Server Time: 2026-09-21 17:40:37 UTC
