Can someone help me identify this otis machine, I am trying to locate Seals for it- Otis parts manual says it is a type H #2 SWT (27BT) but SEES or Texacone does not reference any of these numbers.
That is a #2 Machine, with a modded motor. The number one and Number 2 machine used the Oakum packing material and not a rubber seal. You can Google Oakum Packing Material. Usually unless it has been damaged you can tighten the packing nuts a flat at a time unltil leak slows or stops. Caution do not overtighten.
Thank you very much Rolly
measure shaft OD and box OD. i have used ones from texacone, never had much luck especially when the shaft is gouged/pitted/etc. up hill battle i'd say... as far as tightening old mechanic taught me after a few dozen runs if you cant hold your hand on the shaft then it's too tight.
PHP: 8.3.33 Page Time: 0.020s Queries: 23 (0.006s) Memory: 3.0125 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-20 22:17:29 UTC
