#28693 02/07/20 07:49 PM
W Online: Content
I'm getting a 663 fault and the car is on the Top Directional Limit. I am unable to run the car down on INSP. I have 108 to 115 jumped out to try to run of the top limit with no luck. I have adjusted the brake and it is appears to be working properly. My encoder appears to be working correctly.
Appreciate any help. Can't check any drive settings. If the Accord drive is bad does anyone know where to get it repaired?
W Online: Content
Also getting a 1551 fault -- Governor Slack Rope Switch Activated
W Online: Content
Are you by chance on the safties? Can u bump up?
Probably need to get that slack rope switch jumped or reset. It actually wires into the bottom HN card so you can’t jump it from the machine room. You’ll need an RRF to clear it after it’s reset.
A lot of early installs took the slack rope switch into the lower safety string, so it was in with the pit stop switch. Also had another version where slack rope switch was brought directly back to controller and I/O was put into spare port...
PHP: 8.3.33 Page Time: 0.021s Queries: 26 (0.006s) Memory: 3.0183 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 01:51:25 UTC
