#28719 02/14/20 01:57 AM
Just took on a few of these units, have a car stuck in “Init Shutdown” after a loss of power. Have not encountered this when the car has had the line out in the past. Nothing indicative of this in the fault log, reset faults, etc. Any idea?
Mike G #28720 02/14/20 01:49 PM
Do you have IMS? If so what version?
Mike G #28721 02/14/20 02:15 PM
Open your IO map and check your IO’s. There is a mismatch or an IO in the wrong state.
Mike G #28722 02/14/20 04:27 PM
1 Offline
There are a few 2a pico fuses on the cpu I have had One of them blow after a building power issue gave me a similar issue. Worth a shot just make sure you pull them to check them.
Mike G #28779 02/28/20 03:19 AM
underdog
underdog
Hello friends. I have IMS software. IMS 32 bit ,16 bit
I also have the latest version of IMS 2.7 now.
Email me at [email protected] for details.
Mike G #28782 02/28/20 03:40 AM
ELEVATOR Mechanic
ELEVATOR Mechanic
replace the CPUA software.
Mike G #32015 11/03/21 12:21 AM
20 yr tech
20 yr tech
You ever get this resolved? I am having a similar issue. I n i t shut down. 1014 fault. I got that to go away using IMS fast command "GET". Then "WRT". Now though it is having a RUN MNT shutdown. Won't run up on inspection. Any ideas?
PHP: 8.3.36 Page Time: 0.028s Queries: 28 (0.009s) Memory: 3.0270 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-06 05:09:15 UTC
