2 members (RedLunar47, ot1989), 52 guests, and 2 robots.
#28751 02/25/20 04:17 PM
We can't get the display to show up on our monitor. The forward button is flashing only. Car will run on inspection but will not run on auto.
We have changed monitors already. Any help would be appreciated.
Andrewh #28756 02/26/20 12:54 AM
Have you checked the voltages on the SPU Link Board?
Andrewh #28757 02/26/20 01:08 AM
Power supply is probably high. Car will act funny if it's over voltage. Check ur power supply.
Andrewh #28762 02/26/20 07:15 PM
Voltage on both power supplies are 24v. This car was running fine until Saturday. Everything shows that it wants to run but car will not. We can push a call and it will hold but won't close doors or anything. Have a computer but it won't let me pull up the diagnostics for some reason. Trying to see about getting another.
Andrewh #28763 02/26/20 08:16 PM
Be nice if you said the model of the swift? They do have several models.
Andrewh #28764 02/26/20 08:45 PM
Only thing I got is swift futura no model.
Andrewh #28765 02/27/20 03:10 AM
Swift Futura is one of the models, Merida is another, and 5000 is another.
Andrewh #28767 02/27/20 04:38 AM
There should be a 5v test point (TP5) on the SPU Link Board, you don’t make mention of that in your reply. What color is the SPU button on the upper left? Should be green. Red is no SPU running.
That power supply is located behind the SPU Link Board. Is the SPU “On/Off” switch in the ON position? Are the F1 thru 6 front panel breakers on?
Most all fixtures are 24v, hall or car.
Spu button is green. Spu is in on position. All breakers are on. Will have to check the test point. Everything on the wizard shows connected and working but even if we run the car to the bottom it won't reset or change the position indicator.
Andrewh #28773 02/27/20 04:08 PM
Tp5 is getting 5.01 v
Andrewh #28783 02/28/20 04:14 AM
Well heck.
Only other thing I can think of is the EPU Link Board on the car top. It too has fuses, one being for communication “from” the car.
Andrewh #28798 03/03/20 03:57 PM
Please feel free to contact Issa Lwaysi from Miltronics Inc. @ (917) - 417 - 7389. We provide FREE Tech support for all CEC swift 5000, Futura, & Merida related equipment. 24/7 SUPPORT
PHP: 8.3.36 Page Time: 0.031s Queries: 38 (0.009s) Memory: 3.0514 MB (Peak: 3.5929 MB) Data Comp: Off Server Time: 2026-11-06 02:06:31 UTC
