#28813 03/06/20 02:47 AM
Can you use a UIT on a TAC50-04 like a TAC32H? Where you can enter the security code and go into the programming menu? I have a UIT on a TAC50-04 but it only displays speed and direction info. Unable to access programming menu.
wltr00 #28814 03/06/20 04:48 PM
I think that means it isn't the original with that board. Im sure it would need software to operate on a different CPU. I have a job of 4 units when they changed the CPU that UIT no longer works on that controller
wltr00 #28822 03/08/20 05:19 PM
BART tools, UITs, drive issues etc...you should give in and get a proper updated ims tool and make your life a whole lot easier!
wltr00 #28825 03/09/20 03:03 PM
He’s right, UIT is a painful way to work on Thyssen equipment. Another possibility If they are still with the correct car and a 16 bit controller is if the CPU was replaced sometimes the UIT won’t work unless you copy the 07c file, rename it 0f8 and load them both. That goes for Tac20 and 16bit Tac50-04.
PHP: 8.3.36 Page Time: 0.030s Queries: 22 (0.010s) Memory: 3.0123 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 00:09:51 UTC
