One of my fellow mechanics is having a problem with the car randomly going to different floors without any input such as car calls or hall calls. Sounds a bit strange to me. I was thinking that it could possibly be power supply problems. Any other thoughts? Thanks!
I Online: Content
The power supply is definitely the place to start.
TC7 Offline
I've heard of this happening because its parked at a floor and loses DZ input, at which point the car thinks it's not at a floor, so it runs to go find one. I think in this case DZ magnetic switch was replaced, because the internal contacts weren't conducting well.
That's a great idea. I'll let him know to check that. Thanks for the input TC7.
Does the car run to a random floor after making a run, or does it just sit at a floor and randomly go to a floor?? Do the lights for car and hall calls light dimly on the cards? If the former, look into the closing sequence. First you get the gate signal, (X5 I think), then you get the door lock (X8 or X8a), then you break the DCL. I have seen x5 go high and then go low for a second, (dirty gate switch in Operator), get x8 and then get x5 aagain and this causes the car to run one floor (up if you have 4 slot cards and down if you have 3 slot cards.
If the latter, look for a bad ground. The board ground is the center tap on the transformer.
Thanks Johnny. Those are great tips. I will have him check into these.
PHP: 8.3.36 Page Time: 0.032s Queries: 26 (0.011s) Memory: 3.0203 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 17:04:18 UTC
