I’m currently door a claddagh door lock monitor over lay on
A dover dmc. They didn’t draw in the print where I can get my door limits from. There is a dol. door open limit and door close limit. In the board. And they do work and light up. Does any body know. Which pin on which plug they are. Thanks
You need to install a micro switch for the limits on the hangar track for each limit. you cant use the signal on the door board.
Ok. I have that all worked on. Now. The claddagh door lock
Monitor prevent motion by opening the bdl. Or the tdl. Which I did. But it threw major crap into the elevator. I don’t have the dmc computer but I’m sure it said bdl not when expected. Or somthing. I then went to put everything back so the car work run. And of course I find a bad wire in the switchtree itself
PHP: 8.3.36 Page Time: 0.023s Queries: 20 (0.005s) Memory: 3.0028 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-04 21:28:25 UTC
