#28983 03/29/20 08:08 AM
Hello all,
Is anyone familiar with the cec swift wizard software. I have the wizard software installed in my laptop. But can’t get pass the login password. Aren’t these login passwords standard for all? And I hear there are different passwords that give you higher access. Is this true?
Msd Offline
Try LCD, Install as the PW
Daniel,
If the standard default password doesn’t work (ins****) which I assume you’ve tried, then someone has unwittingly or intentionally set you up. This is most unfortunate if it’s true either way.
And yes, there are different passwords for different program levels, but for us end users, I’ve never found it even remotely necessary to access them.
thank you, i've tried the default password. no luck. i was hoping that with a higher end password i would be able to some how reset the PW through the terminal.
INSTALL
HUDSON.BAY
SNOW-FLAKE
LIGHT(SP),BAR (SP) is space bar
Notice they are all Upper Case
Had no idea about the different PW's look forward to seeing what they are all about...Thanks for sharing!
Please feel free to contact Issa Lwaysi from Miltronics Inc. @ (917) - 417 - 7389. We provide FREE Tech support for all CEC swift 5000, Futura, & Merida related equipment. 24/7 SUPPORTPlease feel free to contact Issa Lwaysi from Miltronics Inc. @ (917) - 417 - 7389. We provide FREE Tech support for all CEC swift 5000, Futura, & Merida related equipment. 24/7 SUPPORT
I was never able to use any of the PW to log in. It’s like many of you said, Either the password was changed or I’m assuming the software is corrupt.
Would anyone happen to have the software files to do a fresh install of the wizard?
Hi Daniel718,
Were you ever able to gain access to the controller? We have the ability to change all programmed passwords back to default while still keeping parameters and application software backed up.
We would be interested to hear the outcome, I hope you were able to resolve the issue.
Regards,
Issa
PHP: 8.3.33 Page Time: 0.024s Queries: 32 (0.005s) Memory: 3.0346 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 15:05:36 UTC
