Page 1 of 2 1 2
On an Otis 22 CT geared machine- circa mid 1970's- (basement traction) Doing a Worm gear removal. After landing the counterweight, and hanging the car-
Ring gear has already been removed, now replacing the worm gear.
1. Remove flange mount motor.
2. Remove thrust bearing cover.
3. Remove three allens holding thrust-to-worm retainer plate, set aside.
4. Remove bolts holding brake-side worm bearing retainer plate, (where the shaft seal is).
5. Remove brake spring, loosen brake shoes off, clear of brake drum. Worm now spins freely.
6. Tug on brake drum, pulling worm out of machine from the brake side. There is a spanner nut, that holds the brake sheave onto the worm. It is recessed, where a spanner wrench won't fit onto it. We could coax it around with a single jack and a punch, but there seems to be no reason to do so, since it looks like the brake drum can come out with the worm together as a unit.
Did all this, but worm gear will not come out of the gear case.
Brake side worm bearing looks like it just presses in, perhaps more force is needed to pull this bearing out with the worm?
Thrust bearing inner race will spin on end of worm, suggesting the thrust bearing is not seized to the worm shaft. Perhaps the worm gear comes out from the thrust bearing end of the machine? Any ideas? Have I missed a something?
Also- Are the sheave shaft bearing caps eccentric? Seems to be no obvious way to adjust the backlash.
hey vic. not sure of the otis seperation but normally i would look at the width of the worm gear and that should let you know which end it comes out of ie the wrong end probably will be smaller. also im assuming the ring gear is the what we call the crown wheel attached to the traction sheave(ive seen some fitters trying to remove a worm gear without removing the crown wheel!). also alot of machine require packers to adjust the backlash of the machine.
Uppo, looking at the worm gear, it has two bearings, one on either end. One is the thrust bearing, the other is the idler bearing, (the idler bearing is by the brake sheave end of the machine). Both bearings are pressed into the casting from the outside, into the machine housing. In both cases, if either one of these bearings is removed, then the worm gear could pop out either side of the machine. Because both sides worm bearings are larger than the worm, so once the bearings are out of the way, there is no obstruction to the worm coming out. So it looks like it could go either way. I'm just puzzled why it isn't moving yet. I'm gonna put some light pressure tonnage on the worm, pushing from the thrust bearing end, to try and push it out through the brake end of the machine. I think maybe that bearing on the brake side of the machine is pressed in under some fair amount of pressure, so it will have to be "squeezed" out, with the worm.
"Crown wheel", sure, that makes perfect sense, even though it's the first time I heard that term. If you wanted to take the worm out, without first removing the crown wheel, maybe you could unscrew it as you pull it out? IDK, just wondering.
What are "packers"? Is that what we call "shim" plates? You know, little thin pieces of metal, used to adjust parts of machinery?
This sheave shaft has no shims anywhere, to raise and lower it. On each end of the sheave shaft, there are angled pin-roller bearings, which ride in removeable outter races. These outter races have horizontal bolts, threading into both the machine casting, and the crown wheel cover. The race itself becomes a "fishplate" of sorts, securing the top cover onto the lower machine casting. It is not possible to fit shim stock into this arrangement, to effect any change in ring height. The only possibility would be if the outter races were eccentric, then they could be rotated, and the ring would raise and lower according to the degree of rotation of the outter race(s). But the 6 bolt circular hole pattern means that the adjustment would be in steps, and not infinitely variable. Doesn't seem likely that Otis would do it this way. Of course, the worm has no ability to move vertically either.
Looking at the outter races, there is no apparent eccentricity to them, either.
Weird.
Here you can see the sheave shaft pin roller bearing. The outter race has been removed, not in picture.
ok had a talk to an otis guy. what is the reason you are removing/replacing the worm gear? is it bc of the backlash? if so the back lash is adjusted via the thrust bearing end. most of the time the tab washer has broken. is the worm gear at the thrust end threaded. if so to adjust the backlash you have to -
-remove thrust cover
-there is a screw to adjust the worm(is about 1 to 1.5 inch wide), sort of with a half screw head that i think has a tool for it but you can use a flat screw driver to adjust the worm in and out.
-when you have moved the screw to the desired point flip th tab into place to lock the screw down.
- now you generally do this with the counterweight landed and everything still attached.
not saying this is for every machine but it most likely the same.
now when removing the worm you disconnect the collar on the brake drum, remove the thrust cover, with a bin lid underneath to collect the oil, the whole worm should come out the rear end with the crown wheel removed. you may need to undo the ring nut assembly on the thrust end , not sure.
not sure why your replacing the worm but try this and let me know.
cheers mate.
Hmm, interesting...
Thanks for checking around, I sincerely appreciate it.
For the backlash adjustment, I don't think this particular machine is the same as you describe, but I will take another look at it tomorrow.
It sounds much easier to take the worm out from the thrust bearing end. I can see how that works- because the thrust bearing is made to be replaced, so it's easier to take out. Whereas the other worm bearing, (closest to brake end of the worm), doesn't generally need replacing, since it doesn't operate under as much end-play stress as the thrust bearing. So the brake end bearing is probably pressed in, which explains why the worm didn't budge, under tension applied from the brake end.
Unfortunately, this machine is facing the wall, so taking the worm out through the back end, (thrust bearing end), isn't a practical option. I wanted to swap in a good (but used) worm, because this worm is somewhat pitted. I don't want the pitting to wear away a good ring gear.
you know what i just realised that there may be no room for a rear exit. man i hate when they dont think about this.i was told you should be able to knock the worm assembly straight out when uncoupled from the brake. also the shimming of the crown wheel assembly is on for teeth matching (depth) and balance for the crown wheel so no eccentric stuff happening there. have a look and let me know.take a couple of snaps of the rear for us to see what going on there if you can.
Will, do, I'll be out there today.
Thanks for your interest!
Ok, seems the worm comes out very easily from the thrust bearing end, just as one would expect.
The idler bearing on the worm at the brake end of the machine is pressed in, and the worm won't go out that end, unless you pull that pressed-in bearing. So if your machine thrust-end is facing a wall, you have to unbolt it from the bedplate, and spin the machine around.
As far as "backlash", I'm referring to the gap between the crown and worm teeth. Maybe it's just confusion of terminology.
As I read your post, I think you are describing the "end play" of the worm, the distance it can slide back and forth horizontally within the machine. At any rate, my 22CT machine worm gear does not have a threaded end, no spanner nut, and no bolt to adjust it in any direction. It has a retainer plate, that locks the worm gear into the thrust bearing inner race. It's held on with three allen bolts, then safety wired.
Someone said that there are no adjustments for the wrom-to-ring engagement.
Going back tomorrow to finish up.
hey vic. it seems you had to spin the gear box to get it out. what a pain. also im referring to backlash as the rocking of the gearbox on stopping, which indicates the wearing out of the worm gear. the end play you refer to is the adjustment for the backlash common on otis geared machines. you are basically making the friction point of the worm gear and crown wheel closer/hard up against each other to stop the backlash motion.i mentioned that the crownwheel bearing that fit to the mount are shimmed to fit square not for up/down adjustment.it looks like there is no worm adjustment on this machine/s.
glad it worked out for you vic.
cheers mate.
Oh, ok, I see what you mean now.
I learned one more thing about the machine- If the crown or ring gear is not directly over the worm, then the top cover will not go down and mate properly with the machine casting.
Thanks for your help with this. It's great to have someone to bounce ideas off of, and share info. I appreciate your input very much.
Cheers!
no problem mate
cheers.
there is an worm end play adjustment. use the plastic shim/gaskets on the thrust plate. and the backlash is adjusted by the spider eccentric bearing races. there are many special tools for tearing these CT machines down.
Thanks so much, Greenpants.
We saw that the outer sheave shaft bearing races have bolt holes 30 degrees apart, indicating that the bearing race can be rotated, to raise or lower the ring gear mesh into the worm. The adjustment is very slight, by my way of looking at it. I've seen other manufacturers that (relatively speaking) have a tremendous range of adjustment for the backlash. I guess Otis figures that if more adjustment is needed, beyond the design parameters, then you got other worse problems, that shouldn't be compensated for by an adjustment.
hey greenpants is this a typical otis geared machine of 70's era as this description of a non threaded worm is not what seems standard here in oz from what ive been told. ive never had to strip one down yet?
the worm is treaded on the end for the spanner nut that holds the brake hub onto the worm. on the trust end there are 3 tapped holes for 3 hardened bolts and a lock plate that hold the thrust bearings on the worm.the thrust bearing cap applies pressure to the thrust bearing race that is adjusted by the plastic shim/gaskets. usually .002-.004" thrust end play. the ring gear lash/backlash adjustment is done with the eccentric bearing hubs on the spider typically its .006". alignment left and right is the shims on the eccentrics. these are standard tolerances for worm machines. and the reason there is not much adjustments is because the initial machining was precise. its not like a cheaper hollister- whitney machine where a rough cast is done and each component has a 1/4" of shim to make adjustments. each way has advantages. that little 22ct moves 3500# cars up to 500fpm. pretty impressive for such a small gear.
Great description. Clear and accurate. Thanks.
thanks greenpants. i will have to speak to my otis mate as this is not the description i was given although i dont think we have any geared machines going 500fpm. maybe its a machine not used here.
cheers mate thanks.
otis used these 17ct, 22ct, and 29ct machines from the early 70's on through the early 90's it replaced to #1 and #2 machines. then they went with the 18atf which is a good machine but a throw away gear box. which we don't make anymore, oops. nowadays everybody has gone gearless and they are working on a gen2 mod machine which will replace most smaller geared machines. everything else we just buy hollister-whitney.
thanks mate next time im in a otis motorroom ill check the machine label. very interesting. cheers mate have a good 1.
Page 1 of 2 1 2
PHP: 8.3.33 Page Time: 0.033s Queries: 55 (0.009s) Memory: 3.1241 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 03:33:11 UTC
